3rd Gen & 4th Gen Rear Ends
Old Mar 3, 2011 | 12:40 PM
KingsHustleLA's Avatar
Car: 1986 Camaro
Axle/Gears: 411
I Just Put A 4th Gen Rear On My Iroc Yesterday And It Looks More Tacky Than I Thought With The Extra 2 Inches On Each Side, & I Heard You Can Take The Disc Breaks Off Of A 4th Gen. Rear By Unbolting Those 4 Bolts In The Back Of The Brakes And Remove The Drum Brakes The Same Way On The 3rd Gen Rear End & Put The 4th Gen Disk Brakes On The 3rd Gen Rear End, Is That True? Also 2 Questions, 1. Is It A Pain In The *** To Do? & 2. Is The 3rd Gen Rear End As Strong As The 4th Gen Rear? My 3rd Gen Has A After Market Axel & Also 373 Gears, Im Wondering That Because I Plan On Doing An LS1 Swap So If I Can Use My 3rd Gen Rear End & Just Swap Out The Drum Brakes To Disc Brakes That Would Be Great! Haha
Old Mar 3, 2011 | 12:51 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Re: 3rd Gen & 4th Gen Rear Ends
i'll answer what i can.
the rear ends are basically of equal strength, though if you have better axles in the third gen, that one is probably stronger
Old Mar 3, 2011 | 12:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Most, if not all, of your questions will be answered here:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
jbd1969
Aug 17, 2015 07:06 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
