700r4
Old Mar 21, 2011 | 04:42 PM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
700r4
anyone have these live making about 550 hp?
Old Mar 21, 2011 | 05:50 PM
crackitoff's Avatar
Engine: Shafiroff 434
Transmission: Jake's Performance Stage 4 TH400
Axle/Gears: Strange S60/spool w/ 3.73's
Re: 700r4
i have a 700R4 behind my 434 shafiroff motor in my 88' and it held up to 652hp at the wheels for 4 years. i had it freshened up last year because the 3-4 clutch pack was just starting to wear causing a delayed 3 4 upshift. all the hard parts inside the trans have been replaced with parts i got from transmissioncenter.net. this year we should be puttin' 800hp to the ground with 2 stages....so i guess this will be the TRUE test to see if it holds up to what we throw at it.
ern
Old Mar 21, 2011 | 05:57 PM
james.gould150's Avatar
Car: 1991 z28
Engine: 305 tpi
Transmission: 700r Automatic
Re: 700r4
does a 91 z28 305 tpi auto have the 700r4 stock or is it another trans ? and if i put a turbo 350 trans in do i need a new computer?
Old Mar 22, 2011 | 10:36 AM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
Re: 700r4
ern
ill cross my fingers and see what happens.
Old Mar 25, 2011 | 11:14 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: 700r4
james the 700r is stock in a 91 f body. not too sure on the second question tho...
Old Mar 25, 2011 | 11:51 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: 700r4
Hey James, Is this you from Tucson? If so this is Robin, With the 89 RS..
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
