Transmission jumping upwards
Subscribe
Apr 18, 2011 | 11:26 PM
Every time I drop the clutch in first gear, or shift to second gear, and drop the clutch again, the stick shifter jumps upwards, which would be the transmission. If I shift smoothly and ease the clutch out easily, it doesn't do that.
I crawled under the other day but the transmission was perfectly bolted up. Isn't there a rubber and metal brace that holds the tranny from the bottom? If so, I don't think I saw one.
I recently had a new clutch put in 2 months ago, the problem started 2 weeks ago.
Any thoughts? I don't think the tranny is going bad, It still shifts smoothly without grinding gears.
Reply 0
Apr 19, 2011 | 01:32 AM
Re: Transmission jumping upwards
Your rear trans mount is more than likely broken. You can use a floor jack under the trans pan and GENTLY jack the trans upward, you should see where the mount is broken or even missing bolts. Good luck
Reply 0
Apr 19, 2011 | 05:33 AM
Ill check it out again today.
Reply 0
Apr 19, 2011 | 06:31 AM
Should you need to replace the mount, the following info may help in your making a decision about type:
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
Reply 0
Apr 19, 2011 | 08:17 AM
Just took a closer look now, and it is in fact the transmission mount. Thanks for the help guys.
Reply 0
Subscribe
