T5 to T56 swap
Old May 4, 2011 | 01:21 PM
rdsiler's Avatar
T5 to T56 swap
Will someone please tell me what parts I need to get in order to swap out my T5 to a T56? Is this a pretty straight forward swap with an existing manual shift car?
Old May 4, 2011 | 06:02 PM
Jaxom's Avatar
Car: '89 IROC-Z
Engine: StealthRam 355
Transmission: 6-speed
Axle/Gears: 3.70 9-bolt
Re: T5 to T56 swap
It's very straightforward if you use a trans from an LT1 car. You'll need these from the donor:
trans, bellhousing, clutch assembly, flywheel, clutch hydraulics, clutch fork & T, slave cylinder spacer, shifter, shifter boot (the one that bolts to the floorpan,) torque arm mount
You'll also need a swap-specific crossmember. Hawks and Spohn make nice ones.
It's mostly a bolt-in swap, with the exceptions being that the shifter opening in the floorpan needs to be extended toward the rear, and you'll have to do some adaptation to get the speedo to work. There are a couple of different ways to go about that, just run some searches. You can use your stock pedal assembly by adapting the new slave cylinder and pressure hose to your factory master cylinder. You just have to file down the ridge at the tip of the steel fitting on the end of the hose.
Old May 4, 2011 | 06:26 PM
Shadow Z's Avatar
Car: Lots of 'em
Re: T5 to T56 swap
Jaxom basically covered it, but here's a full, detailed write up.
http://www.skulte.com/T56.html
I really recommend it. The T56 is kind of picky about 3rd gear, gotta jam it just right, but if you have the driver mod, it's a beautiful transmission. This is a video I had a friend record of my T56 swapped '01 GT about an hour ago. Obviously not the same car, but still the same great trans. It's nice knowing that after 4th gear, I can still pull a little more, instead of being knocked down by the original TR3650 5 speed's .67 5th.
http://www.youtube.com/watch?v=zsubO-srs-k
Although I don't really like the GM overdrive gears for the T56. They're pretty steep compared to the Cobra T56, with a .79 5th gear and .63 6th. It makes pulling from around 120-150 in 5th gear pretty easy, since I'm more into roll racing and top end speed, and still an awesome .63 6th for a highway gear. Even with my 3.73s I do 70 at I believe exactly 2,000.
Old May 13, 2011 | 04:56 PM
1991z285speed's Avatar
Car: 1991 z28 Camaro
Engine: 5.0 H.O. TPI
Transmission: Borger Warner T5
Axle/Gears: 3.07 gear ratio
Re: T5 to T56 swap
Here you go man, this will help you out a lot. Best of luck and put up photos!
https://www.thirdgen.org/forums/tran...56-fit-my.html
-T
Old Jan 17, 2016 | 05:49 PM
zygee's Avatar
Re: T5 to T56 swap
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 30, 2015 10:03 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
