LT1 T56 clutch Fork torque spec?
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
Sorry guys. I tried searching but cant seem to locate it. Im about to slap in a T56 and wanted to see if anyone knows the torque spec before I install. Fork just seems really loose.
Kris
Kris
Car: `86 SS / `87 SS
Re: LT1 T56 clutch Fork torque spec?
The bolt should be tight; I like red loctite.
The fork clip is going to seem loose. The fork has to slide onto the TO brg once the trans is in place.
Night rider327
Sep 2, 2015 04:17 AM
bolt, clutch, fork, install, lt1, pp, replacement, shift, size, spec, specifications, specs, t56, torque, transmission
