wc t5 grind out of neutral
Old May 14, 2011 | 05:26 PM
1986350's Avatar
Car: 1985 Pontiac trans am
Engine: 350 4bbl
Transmission: 5-Speed
Axle/Gears: limited slip
Hey everyone this is the third tyranny I've gone through because of people on Craigslist selling bad trannys. Ok so I have a semi new clutch and throwout bearing and this is a wc t5 out of a camaro I've never powershifted or down shifted at a very high rpm but I do drive spirited sometimes and flex a v8 but the other day I put it in first and made a turn and the house I was pulling up to was right there, so iwas doing maybe 2200 rpm pushed in the clutch and pulled it into neutral and I could hear a grinding sound now I'm worried and just want to put in a 700r4 just not to worry about it anymore please help
Old May 15, 2011 | 12:05 PM
1986350's Avatar
Engine: 350 4bbl
Re: wc t5 grind out of neutral
Bump do you guys think it could a fluke thing or maybe the throw out bearing or clutch
Old May 17, 2011 | 11:27 AM
fissionfusion's Avatar
Car: 1985 Pontiac Trans Am
Engine: Chevy 350
Axle/Gears: GM 10 Bolt
My T-5 has a similiar problem, but it's less of a grind, more like a supercharger whine. Reason for is that is either the input shaft bearing or throwout bearing.
My opinion, drive it into the ground and buy a T56.
92camaro350cci
Oct 14, 2015 09:29 AM
RedLeader289
Sep 23, 2015 06:50 AM
PeteK825
Sep 22, 2015 10:47 AM
InfinityShade
Sep 18, 2015 08:32 PM
Stroopwafel
Sep 11, 2015 06:38 AM
