looking for input.. do i need a rebuild?
Old May 17, 2011 | 12:15 AM
88sporty's Avatar
Car: 1988 sport coupe
Engine: 305 swap
so i finally got my maro on the road today, i took if for a ten mile drive as a test. it went fine on back roads at first, then i took it on the highway for the way back. but after i let the car sit before i took it home, it would rev way up like 4k r's before shifting, it did this through every gear, and would shift very hard every time. for the record its a carbd 305 backed by a 700r4. any comments or suggestions are welcome if anyone can help it would be appreciated!
Old May 17, 2011 | 12:38 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: looking for input.. do i need a rebuild?
you say you finally got it back on the road. so how long was it sitting for? when cars site for awhile the torque converter tends to drain back into the transmission. eventually leaking out. it could be low on fluid. id check that. Vehicle needs to be warmed parked on a level surface with the car running in park. Should be in the crosshatch area on the transmission dipstick which is located on passenger side of engine compartment toward rear. Good luck. If not, have you messed with the carburetor? you TV cable could be misadjsuted google tv cable adjustment and try yourself or have a transmission guy do it.
Old May 17, 2011 | 09:30 AM
88sporty's Avatar
Engine: 305 swap
its been sitting a few years, but i have filled the fluid up to level and replaced the input and tail seals so far, thank you for the suggestion
Old May 17, 2011 | 08:31 PM
torque_is_good's Avatar
that's the issue. You can try some white shepherd for tranny's and see if it softens up the seals and rubber. It's worth the $10-$15 before tossing a basic rebuild kit at it.
http://www.amazon.com/White-Shepherd...5682240&sr=8-1
Old May 17, 2011 | 08:45 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
I had the same problem with a Th200c. idk if the difference in style of transmission would matter much. anyways, i had to do a rebuild, there were springs and gear pieces everywhere when the pan came off haha, its a miracle my trany lasted as long as it did with so many loose parts. might wanna take a look in there or have a good shop do it. good luck
Old May 17, 2011 | 09:52 PM
88sporty's Avatar
Engine: 305 swap
thank you for the ideas, im going to give the sheperds a shot along with a new filter and change the fluid again, hopefully its not the same case though. i'm just trying to find anything that i can do that may help before a rebuild or replace is necessary, from in my reading here i noticed most will say the series 1 700r isnt really worth the effort in rebuilding. i will give it a shot and let you guys know, thanks again for your suggestions!
Old May 18, 2011 | 12:31 AM
Rob 70's Avatar
Car: F250,83 diesel, many more
Transmission: 4R100, 700R-4
Axle/Gears: 3.73, 3.42
The 700 is worth rebuilding there are a lot of racers use them and of course street rods. You can get it to hold up to 750 hp with a 9-10" converter. Not to mention they have a very low first gear to get you off the line and a .70 overdrive for cruising and keeping the RPM's down. But you do want to start with a 88 and up unit.
If built with the right upgrades this trans will last for years of fun.
But before you do a rebuild the tv valve could be stuck. Idle the car at 1000-1200 and with your hand pull the tv cable from under the hood 20-30 times a lot of the times it will come unstuck. From sitting the shift valves could be sticking a little too. The only thing that I have ever used in one is the Lubegaurd in the red bottle. You can get it from Napa. Before pulling the tranny I would change the fluid and filter fill it with fresh fluid and two bottles of lubgaurd. That could very well fix the problem and save you some money.
Hope that this helps
Rob
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
