T-56 Flywheel Debate
Car: '89 Formula
Engine: 355 SBC, AFR 195s
Transmission: T-56 Swap
Axle/Gears: 7.5 Eaton LSD w 4.10s
Hey all. I'm doing a T-56 swap (to 2 piece rms) and debating the different flywheel choices available. Any way I slice it, I'm looking in the 400-450 range but my question mostly is about the use of aluminum versus billet steel. The Ram aluminum flywheel is even a little cheaper than the Centerforce steel one making it somewhat attractive. The car is mostly street driven with some drag race use so I think I know the answer but I'd like to know what other people are using for their flywheels in T-56 swaps. Thanks
Also, does anybody know if anybody makes a 168 tooth flywheel for T-56 swaps?
Car: `86 SS / `87 SS
Re: T-56 Flywheel Debate
You might want to clarify if you're using a 93-97 F-body LT1 transmission and stock bellhousing or something else. 168t doesn't fit that bellhousing/starter pocket. Aftermarket options allow it, however.
Car: '89 Formula
ok thats good to know. it is the stock bellhousing for a 95 lt1 t56
tonys91rs
Oct 10, 2015 03:31 PM
monte87cortez
Sep 26, 2015 08:10 PM
