Clutch line
Old May 28, 2011 | 10:45 PM
KotaZ71's Avatar
Car: 88 RS
Engine: 3.1
Transmission: t-5
Axle/Gears: your guess is as good as mine
Clutch line
How does the clutch fluid line come apart from the slave and master cylinder?????
Old May 29, 2011 | 08:19 AM
Re: Clutch line
There's a roll pin that holds it in at each end. Goes through the cyl perpendicular to the line. The line has an end with a groove around it that the pin passes through such that it can't pull out.
There's basically NEVER any reason to take it apart unless you're replacing one of the cyls. If that's not what you're doing, spare yourself some extra grief and leave it alone.
Old May 29, 2011 | 02:40 PM
KotaZ71's Avatar
Car: 88 RS
Engine: 3.1
Transmission: t-5
Re: Clutch line
I need to replace my line..It got damaged during the engine swap
Drone358
Dec 10, 2015 08:16 PM
jtwoods4
Sep 3, 2015 05:39 PM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
