changing rear end gearing helps?
Old Jun 7, 2011 | 10:39 AM
sk8r fer life's Avatar
Car: 1990 camaro rs
Engine: 305 tbi
So I have setup, 406sbc - t400 - 3.73posi, and right now it gets like 8-10 mpg if I changed the gearing to a 3.23 posi how much would this affect the mpg? or would I need to lower it further to make it streetable. Im trying to get away from changing the transmission. How much do rear end gear usually cost and where should I get them from?
Tim
Old Jun 7, 2011 | 12:46 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: changing rear end gearing helps?
10 bolts are usually around $200-$250 or so for the parts depending on what you get and where from (Summit, Jegs, Randy's Ring and Pinion, etc). If it's a 9 bolt be prepared to pay more I had close to $500 in parts alone for gear and install kit.
Then figure another $250-$700 for install at a shop. It just depends on where you call around. Dealership were quoting me in the $500-750 range while regular mom and pop places were cheaper.
By the time you pay for gears and install you'll probably be in the $500-$750 range. If it's a 10 bolt 3.23s are everywhere. I got one free few weekends back from a board member. You could just grab a used one somewhere.
8-10 MPG seems pretty low. Is it tuned correctly? Normally you want the gears and stuff setup for how well the car runs in the 1/4 or what the camshaft needs to say in the proper range.
Theres an RPM calculator in the Tech Section on the TGO Homepage. You can use that see how much RPMs will adjust. I would expect 300-400 RPMs though at highway speed.
Old Jun 7, 2011 | 01:39 PM
Car: 1990 camaro rs
Engine: 305 tbi
I was told its so low because it has a Holley 750 dp and no overdrive gear, and I was told it was all probuilt so it should be tuned right only 700 miles on everything
Old Jun 7, 2011 | 02:48 PM
Engine: 383 SBC
Well unless they tuned the carb to the motor on a wideband it's not properly tuned. They could best guess the carb jets sizes and etc but it might be running pig rich. Even using a vacuum gauge I was able to get my old 750DP close, but found lean sections once on the wideband.
Old Jun 7, 2011 | 03:22 PM
Car: 1990 camaro rs
Engine: 305 tbi
So what would be my best option to do then?
Tim
Old Jun 7, 2011 | 04:15 PM
Engine: 383 SBC
I'd start with getting the carb tuned up. Carb Board has a Holley tuning sticky.
Old Jun 7, 2011 | 06:39 PM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
Axle/Gears: 9 bolt, 3.45
Could always swap a vacuum secondary carb on such as a Holley street avengor 670.
But in the end, if your worried about gas milage maybe get into hondas?
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
