87 Firebird rearend to?
Old Jun 23, 2011 | 01:46 AM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Hey i have a 87 firebird 305 carb with auto tranny, thought to be 2.73's with limmited slip
I was wondering what rearends besides 3rd and fourth gen cars will fit? Mabye some s10 or old 4x4 truck with lower gears and posi? Anyone know what other vehicles have same size?
Old Jun 23, 2011 | 01:52 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: 87 Firebird rearend to?
Basically limited to 3rd and 4th gens due to the Torque Arm being required. 4th gens are a little wider than a 3rd gen.
That being said you have 9 bolts, 10 bolts, and Dana 44 (good luck) that came in the cars.
Old Jun 23, 2011 | 06:15 AM
As always, "limited slip" IS THE SAME THING AS "posi". "Posi" was merely GM's trade name for "limited slip" at one time, and the name stuck.
So if you have limited slip, you already have posi.
However, you probably don't. Those base-model LG4 cars were rarely ordered that way. Although it's always possible that somebody has already put a limited slip carrier in it before you got it. More likely, you have what we would ordinarily call an "open" differential, with UNlimited slip.
No other chassis has a rear that will fit these cars. Gotta be a 82-02 F-body. 93-02 rears are longer and will make the wheels stick out funny and look poseur, especially if they're the stock pizza cutter wheels, either the 15s or the 16s, that came on these cars. However the combo of 93-02 rear and 93-02 wheels fits the same as the combo of 82-92 rears/wheels, because the wheel backspacing difference exactly offsets the axle length difference.
Old Jun 27, 2011 | 12:52 AM
Car: White 84 z28
Engine: Chevy 350
Really not any other truck or car have the same dimensions? Not looking for a proffesinal build, just a fun cheap red neck ride
Old Jun 27, 2011 | 01:19 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
It isn't so much the dimensions (width), as it is the suspension type. No other car or truck came with 2 trailing arms, a panhard bar and (the biggest issue) the torque arm. Some had those types, but not the same lengths or positions.
So no...No others will be a swap. Unless you are ready to do some serious cutting & welding.
Old Jun 27, 2011 | 06:15 AM
Engine: 383 SBC
Brackets can swap over easy enough with some cutting and welding. The biggest issue is the torque arm, like stated earlier. It's cast into the pumpkin design itself. There is no bracket to cut and swap for that one. You'd have to make your own. By the time you do all that it'd be far easier just to grab a good used one from a yard for $200.
jtwoods4
Sep 3, 2015 05:39 PM
jtwoods4
Sep 3, 2015 10:19 AM
90formulaVortec
Sep 3, 2015 09:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
