Junk yard ford 9" rear axle
Old Jul 25, 2011 | 11:34 PM
Fiddler12's Avatar
ive got a junk yard ford 9". Do they make kits to make thin work with are cars? Or do i have to get one that has all the stuff on it?
Old Jul 25, 2011 | 11:38 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: Junk yard ford 9" rear axle
some guy did a post where he welded the f body axels to a 8.8 housing. maybe he will do a write up on it or something
Old Jul 25, 2011 | 11:39 PM
Car: 1990 camaro RS
Engine: 305 TBI
https://www.thirdgen.org/forums/ltx-...t-left-11.html post 505
Old Jul 26, 2011 | 12:36 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Too much work if you ask me. I believe I've also seen a post someone took 9 bolt axles and tubes and converted them to a 9 inch center. It took a lot of welding and a jig that was custom made to do it. After all that sure you get a 9" ring with unknown mileage and usage, but you still have little 28 spline axles.
$975 or so will get you an aftermarket housing thats all ready for a center section.
If you convert a junk yard one it needs to be the proper spacing (cut to fit), needs spring perches, LCA mounts, and most importantly it needs to have a torque arm bracket mount. That's the big one the torque arm bracket on the 9 bolt and 10 bolt are cast directly into the pumpkin so there is no easy way to cutting and welding it. Most aftermarket ones use a mount that bolts off the centersection or just provide ears and a custom torque arm is required to hook it up correctly.
Maybe 5+ years ago many people were going JY conversions, but in the past few years aftermarket centers and bolt-ins have gotten cheaper and are more strudy than a 20-40 year old 9" you pull out of a salvage yard.
TheJoeY88
Dec 31, 2016 07:30 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
E Rod
Aug 28, 2015 05:17 AM
bbernardo94
Aug 19, 2015 05:25 AM
