rear trans.seal replace whats involved?
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
at first it just dripped now its pouring from it. i have it on ramps i am wondering wats all involved with changing it?
re: rear trans.seal replace whats involved?
DO NOT tap it in around its edge!!! It will leeeeeek, GUARANTEED, EVERY TIME.
Instead, take a 2x4 and hole-saw a large enough hole in it to fit over the end of the mainshaft, and nail it to another piece of 2x4 without a hole; set the seal in place; set the wood against it; and with one mighty whap of the B(est)FH you can find, bonk it in there.
Consider taking the extension housing off and running it over to the neighborhood transmission shop, and having a new bushing knocked into it. Seals basically NEVER fail of their own accord; about 99.999% of the time, the reason they leak, is because the thing they're supposed to be sealing, is wobbling around instaed of running straight smooth and true.
Or of course, replace the seal 2 or 3 times, curse a little bit about what pieces of crap they are, and THEN fix the true underlying problem to the symptom.
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: rear trans.seal replace whats involved?
well i think i made it leak. from when i jacked motor up to put a new oil pump in it .
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
guess what it wasnt the seal it was coming out of the vss. dam it it was just rebuilt 800.00 bucks and they cant tighten a ten mm bolt?
eightsixseven
Dec 16, 2024 01:50 PM
