Noise and Vibration
Old Aug 18, 2011 | 03:46 PM
Steve-oh's Avatar
Car: 1991 Formula
Engine: 305TPI
Axle/Gears: 3.42 posi
Noise and Vibration
When I first got the car it vibrated when past 80mph, and really bad when I would let off the gas and coast down from 80+mph.
So I changed the U-joints, the broken trans mount, and the leaking output shaft seal.
Now it vibrates horribly and makes a low pitched humming sound at 70mph+. at 90mph the shifter feels like a damn vibrator. The trans mount is just a stock replacement and I disconnected the driveshaft from the rear and rotated it 180*. (not sure if I needed to remove it from the trans too though) Or it could it be I bent the output shaft somehow?
Old Aug 20, 2011 | 12:37 PM
Steve-oh's Avatar
Car: 1991 Formula
Engine: 305TPI
Re: Noise and Vibration
anyone?
Old Aug 24, 2011 | 06:16 PM
Stebo's Avatar
Car: 1992 RS Camaro
Engine: 305 soon to be 383
Transmission: Richmond -6
Axle/Gears: 4:10 with Auburn locker
I'm wondering if the drive shaft has been modified and if so was it balanced? Just trying to think of something you may have overlooked. Hope you figure it out soon !
Old Aug 25, 2011 | 04:23 PM
Steve-oh's Avatar
Car: 1991 Formula
Engine: 305TPI
still havnt figured it out. I dont think a seal puller would generate enough force to bend the output shaft and Ive used the same brand trans mount on my previous Camaro with no problems. Im gonna look for a place that balances driveshafts
Old Aug 25, 2011 | 07:29 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Steve-oh, welcome to TGO.
Odds are that the drive shaft is just plain bad. The way that GM centered the u-joints makes it near impossible to R&R them and end up with a shaft that doesn't have any run-out. The balance ends up worse then when it was stock.
Best bet is to get an aluminum drive shaft. Third or forth gen will fit.
RBob.
P.S. note that GM calls a drive shaft a "propeller shaft."
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
roysatikas
Sep 22, 2015 08:15 PM
InfinityShade
Sep 18, 2015 08:32 PM
