82-92 rear axle code
Car: 1992 camaro z28 convertible
Engine: 5.0
Transmission: 700
Axle/Gears: 277
Bought a rear off craigslist told me it was out 84 z28 but stamped on axle is 4pq co62 1 i think its co62 not in front of it right now but sure its stamped 4pq.
its 10 bolt,rear disk
g80 tag
want to install in 88 iroc-z with 9 bolt disc brake
what year is it and gear,is it posi
any other info would be greatfull
thanks Johnny
g80 tag
thanks Johnny
Re: 82-92 rear axle code
Screw the codes.
If anybody has changed anything inside it, odds are, they didn't change the code. Eh?
Since you're a smart guy, smart enough to post here, you already know that THE FIRST THING you are about to do to a "new to you" rear end, is change the fluid. Since you'll already be having the cover off ANYWAY, just LOOK AT THE PARTS and see what gear it is and whether it has a posi in it or not. Of course you can't necessarily tell just by "looking" whether it's wore out or not (probably is), but the "codes" won't tell you that either.
Engine: 5.0
Transmission: 700
Axle/Gears: 277
ok understand but does any of this codes stamped on tell me what year,if nobody changed anything what do the codes tell me.
thanks johnny
thanks johnny
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Look at the following link under What Gear Ratio Do I Have?
https://www.thirdgen.org/forums/tran...-10-bolts.html
For whatever it's worth 4PQ is from an 83 with limited slip and 3.73.'s.
JamesC
JamesC
hectre13
Dec 11, 2023 08:14 AM
LT1Formula
Nov 16, 2015 01:13 PM
