Clunking in rear when backing
Old Aug 31, 2011 | 05:46 PM
fivestar's Avatar
Car: IROC and 65 Mustang
Engine: IROC V-8
Axle/Gears: posi traction
When I put my 88 Iroc convertible in reverse (auto trans) I get a slight clunking sound coming from somewhere in the rear. My thought is that it might be my u-joints?? this clunking sound when backing up is not bad or real loud but I do not to be a stuck somewhere if somethings breaks and someone here has had the same issue... Hoping you guys can help me figure it out?
Fivestar
Old Aug 31, 2011 | 08:53 PM
torque_is_good's Avatar
Re: Clunking in rear when backing
with foot on brake and car stationary are you saying that when you engage the gear that it clunks?
If so, it's a u joint
Old Aug 31, 2011 | 10:43 PM
fivestar's Avatar
Engine: IROC V-8
I do not get much of a clunk at all when I push on the brake and place it in reverse gear. Actually it is more when I am backing up...it is a series of light clunks while moving backwards. I do not get any clunks at all when I place it in drive and move forward.
Old Sep 3, 2011 | 02:51 PM
mackjar66's Avatar
Car: 1989 GTA
Engine: pending install 383 tpi
Mine is doing the same thing. I had to tighten the nut on the front of the rearend and change the u joint
Old Sep 3, 2011 | 08:24 PM
fivestar's Avatar
Engine: IROC V-8
I am hoping that is all I need to do. going to be checking and changing those things come Monday (next day off) I will keep you all informed. Thanks for the feedback!
Fivestar
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
BlackBoulder
Aug 11, 2015 11:15 PM
MENINBLK
Aug 5, 2015 11:58 PM
