Is this cable bad & I think my transmission is toast
Old Sep 4, 2011 | 06:11 PM
syoung_2000's Avatar
Car: 1991 Firebird Formula
Transmission: 700R4 to WC T5 swap
Axle/Gears: 2.73 drum to 3.73 PBR swap
Hello everyone!
This is my first post. I just bought a 1991 Firebird knowing the transmission slipped. When I test drove it, it shifted best when it was out of overdrive. It did however slip a lot!
This car has 102,000 miles on it and the engine is leaking in a few places too. If fixing this is gonna be too expensive I may have it listed for parts later, but for now am wanting to get it on the road.
Then I drove it the day I bought it. When to park it and when I let off the brakes, it lunged forward. Tried sliding it down into reverse and it drives forward. The shifter is loose (no catching) when sliding it from park to drive.
Also after I shut the car off, if it's in any of those gears that were driving forward, it rolls freely like it's in neutral. I feel like the transmission is shot, but is the cable also?
I have included a picture of the cable underneath hoping someone can tell if it looks normal. I can see some cable where it looks like the plastic parts on both ends should be together???
Thanks in advance!
Attached Thumbnails Is this cable bad & I think my transmission is toast-img_2748.jpg   Is this cable bad & I think my transmission is toast-img_2747.jpg
Old Sep 4, 2011 | 07:22 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Is this cable bad & I think my transmission is toast
Yep - broken shifter cable. Has nothing to do with tranny slipping - only cure for that is a rebuild/replacement.
Old Sep 4, 2011 | 08:07 PM
So, those two black plastic pieces on either side should be together? Is that how you can tell by looking at it?
Thanks for your help!
Old Sep 4, 2011 | 08:11 PM
Car: 1992 RS
Engine: Carbed 350
In the first photo - you can see the actual steel cable - that's where it's broken - shouldn't be able to see the actual cable.
Don't waste time with whatever autozone/advance carries in stock, order a Dorman brand part - takes 2-3 days to get, but the others are junk and will break again in less than a month.
Old Sep 4, 2011 | 09:23 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Sage advice. Also, order 2 regardless of the brand- keep the other in your box as a spare. Before I switched to Dormans, it seemed like everytime I replaced one, the first one would only last a couple weeks to a month- on a 2 day a week driver. Even after switching brands I went through them more often than I would like to admit.
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Scamo-2.8
May 20, 2016 07:01 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
chazman
Aug 22, 2015 02:01 PM
