HELP
Old Sep 13, 2011 | 01:29 PM
Harcourt's Avatar
Car: 91 Camaro RS
Engine: 5.0/305
HELP
SO I HAVE DONE A T5 SWAP IN MY 91 RS AND IT WONT START THE WIRES TO TE AUTO SHIFTER WHERE DO THEY GO? I CUT THE TWO BIG ONES AND PUT THEM TOGETHER STILL WONT START PLEASE HELP ME FIGURE THIS ONE OUT
Old Sep 13, 2011 | 03:26 PM
Harcourt's Avatar
Car: 91 Camaro RS
Engine: 5.0/305
Re: HELP
ive ran the to large wires to the clutch switch. mine are green and purple. still nothing when i turn the key on all my acc come on but when i turn it to start nothing happens. someone please help me
Old Sep 14, 2011 | 03:53 AM
oif0709's Avatar
From: http://www.facebook.com/ThirdGenCamaroFirebird
Car: 1987 Camaro Z28
Re: HELP
So the starter doesnt even engage?
Old Sep 14, 2011 | 08:37 AM
Harcourt's Avatar
Car: 91 Camaro RS
Engine: 5.0/305
Re: HELP
no it dont. i plugged the nutral safty switch back in to the auto shifter and it starts fine. im confused?
Old Sep 14, 2011 | 12:45 PM
oif0709's Avatar
Re: HELP
That might be your problem. There is a purple wire that comes from starter is a little pain in the butt. I just went through hell with mine. What I had to do what strip and connect the wires together that go to the neutral safety switch. Try that and see if your problem is fixed for good. There is a relay that is called your starter enable relay that has a wire coming straight from the neutral safety switch(mine was green with a white stripe). In order for that to send power to the purple wire it has to be connected to it from the neutral safety switch. Just connect them together, put some electrical tape on it and let me no what you get.
