This stupid 700r4
Old Sep 14, 2011 | 03:09 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
This stupid 700r4
I need everyones help on this one I got a 700r4 that just shifts way to early into over drive it's kinda annoying even at wot it just shifts an doesn't go through the gears like what the hell is the matter with this stupid transmission I've tried adjusting the tv cable so many times an still just doesn't want to go through the gears until it's in overdrive
Old Sep 14, 2011 | 06:01 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: This stupid 700r4
I experienced the same problem. Never fixed it, just always drove in drive unless I was on the highway. I'm switching to a t-56 but I'm interested to see what people say.
Old Sep 14, 2011 | 06:13 PM
Pro Built Automatics's Avatar
If changing the TV cable setting (making it tight at WOT) does not make it shift later, then you most likely have a throttle valve problem in the valve body. The TransGo Shift kit can solve this. The modified Street/Strip Shift kit is what I would use here.
Engine: LR4 4.8
Yea I'm switching to a t56 as well really soon actually but it does shift through all the gears really good now I guess but now when I select the gear lever to to go reverse it takes forever to go in an back up what could cause that
loud91rs
Oct 5, 2015 10:05 PM
djmarch
Oct 2, 2015 10:41 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
