can i remove valve body in trans while trans is in car?
Old Sep 18, 2011 | 07:27 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
I need to add a check ball above tv cable bracket. Ball goes above valve body. Can I do this in car with transmission right side up?
Old Sep 18, 2011 | 09:25 PM
Re: can i remove valve body in trans while trans is in car?
Sorry, forgot to add 91 700r4
Old Sep 18, 2011 | 11:12 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
The tv valve check ball that is bigger than the rest of the ***** if so the tranny will work fine without it
Old Sep 19, 2011 | 05:16 AM
We thought tranny would be fine without but tranny shifts too soft and early. Manual and online say it keeps pressure up for firmer proper shifts. Yes, it is the bigger ball.
Old Sep 19, 2011 | 12:14 PM
antoine's Avatar
What was done to the transmission
Old Sep 19, 2011 | 01:43 PM
We did a full rebuild. Clutches, steels, all gears, torringtons, bushings, seals, sun shell, lock out solenoid, trans go shift kit and precision 2200 stall converter. Check ball is port E according to haynes manual. On edge of valve body. Im gonna loosen valve body bolts enough to lower valve body down to fish it in. Ill report back with how that goes.
Old Sep 28, 2011 | 07:09 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
just leave it out. Handfull of those made without the ball. it is for the purpose of going to full line pressure if the tv cable breaks or comes disconnected. If your cable is set correctly, the ball is held off place by the pin on the tv linkage anyway, so, unless you have linkage without the pin, (which are also the trans that were made without the big check ball). so if you put one in, it will be full line pressure all the time = late and very firm shifts. Just FYI, learned from personal experience.
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
NBrehm
Aug 25, 2015 11:49 PM
drathaar907
Aug 10, 2015 07:44 AM
3rdgenparts
Aug 8, 2015 07:09 PM
