LSX and 700r4
Old Sep 25, 2011 | 01:13 AM
ptrblt100's Avatar
Car: 87 IROC Z
Transmission: auto
Axle/Gears: 9 bolt posi
LSX and 700r4
I am building an LSX engine and carburating it so I am using a 700r4 transmission. My question is which transmission crossmember do I use? A conversion for a 4L60E the 700R4 croosmember or do I need to make my own?
Old Sep 26, 2011 | 03:40 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: LSX and 700r4
hopefully your 700r4 is built, as stock form will not last very long behind one of those motors.
however, as long as you get the spohn/hawks mounts or 1" setback adapters, you should be able to use the stock crossmember
Old Sep 26, 2011 | 07:24 PM
ptrblt100's Avatar
Car: 87 IROC Z
Transmission: auto
Re: LSX and 700r4
Yeah I have a pro built unit already to go can take up 800 (www.maddogtransmissions.com). I didn't think the original unit would take much abuse with a substantial increase in power.
Thank you
Old Sep 27, 2011 | 11:43 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Re: LSX and 700r4
Stock Cross member with the correct plates as mentioned above.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
