advice before i take it to a shop please
Old Oct 26, 2011 | 10:51 PM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
hey guys i got a bad somewhat bad shake on my car and i know nothing about drivetrain. it starts aroun 30 or so and gets worse around 65. I've just had my front tires replaced cause the old ones were to big and the new tires had no effect on it. the weird thing is when i turn left, like when im goin up an on ramp, the shaking goes away so it only exists goin straight and turning right. I was told that it sounds like a wheel bearings bad and it does kinda feel like the vibration comes from the front right but its kinda hard to pinpoint. Any help would be greatly appreciated.
Old Oct 26, 2011 | 11:22 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: advice before i take it to a shop please
Make sure you don't have a loose steering box
Old Oct 26, 2011 | 11:25 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
that's where I would start jack up each wheel or both... grab the tire. pull and push quick motion... listen for clicking. also check for front suspension movement. while doing this or have a helper
Old Oct 26, 2011 | 11:29 PM
bigreed91's Avatar
Car: 1990 camaro rs
i'll see if i cant jack it up tomorrow and check that, im ready to get this fixed cause ive never gone more than 65 in my car since ive owned it and i wuld like to dont have people flyin past me on the highway no more
Old Oct 27, 2011 | 02:08 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
wheel bearings are cheap and easy to do. I did some in a parking lot of a hotel on a car of a fellow who had driven hundreds of miles to a car show.
Old Oct 27, 2011 | 07:01 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Check wheel bearings and strut mounts.
Jack up each tire and check for any play holding it at 12 and 6 o'clock positions. Any wobble at all means the bearings need to be replaced. Or just replace them cause they've probably been on there FOREVER.
Pull the dust caps off the strut mounts and observe for tears in the bushings. Have someone turn the wheel while you observe it for play.
Save up and replace all of the wear components. Idler arm, ball joints, centerlink, tie rod ends and strut mounts. Replace everything at one time so you can get it aligned properly ONCE. You don't need all high-dollar stuff and you won't regret it.
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Magman
Sep 12, 2015 11:55 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
tgp1990
Sep 4, 2015 06:24 AM
mrdevontay
Sep 2, 2015 08:04 PM
