LT1 T56 pressure plate question
Old Oct 28, 2011 | 09:01 AM
ssor's Avatar
Hi guys!!
I'm in the process of swapping my 700r4 to an T56, and I'm not sure to understand the pull type pressure plate. Because, when I try to place the pressure plate on top of the clutch that is itself on top of the flywheel, I have a 1/8 inch gap between the clutch disk and the pressure plate sides. Is this normal? Do I simply need to torq down the bolts so the pressure plate will squiz???
Please help guys! I don't want to make a mistake!
Thanks!
Old Oct 28, 2011 | 09:02 AM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Re: LT1 T56 pressure plate question
First clutch job?
Old Oct 28, 2011 | 09:03 AM
ssor's Avatar
hahahahaha yep!!! Well I've seen a couple ones but I never done it myself....
Old Oct 28, 2011 | 09:06 AM
Aaron_SK's Avatar
No time like the present to learn.
Install all the bolts and tighten them till they just touch the pressure plate. Then tighten them in a cross-pattern till the plate compresses to the flywheel.
While you are clamping it down it is a good idea IMHO to wiggle the clutch tool around once in awhile to make sure it is not binding. The clutch disk can get kicked at an angle even with the tool installed.
Old Oct 28, 2011 | 09:11 AM
ssor's Avatar
That's the answer I was looking for!!! Thanks alot!!!
Old Oct 28, 2011 | 10:09 AM
3genpio's Avatar
Car: Trans Am
Engine: 383 Accel ProRam single plain EFI
Transmission: t-56 Spec #3
Axle/Gears: 4 gen 3.73:1
you are not the only one i was also wondering wtf during swap job....
Old Oct 28, 2011 | 11:17 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
27-30lbft with locktite
midge54
Dec 27, 2019 04:14 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
