Camaro rear end
Old Oct 31, 2011 | 11:07 PM
Falconsfan's Avatar
Camaro rear end
Hey guys. I have recently purchased a 87 728 camaro. Its the 305car automatic
was wondering it it was single,positive, or limited slip traction? Any help?
Old Oct 31, 2011 | 11:11 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Camaro rear end
Get the code off of the axle on the front of the passanger side and look it up.
Old Oct 31, 2011 | 11:20 PM
zero2005's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: stock with 3.23
Re: Camaro rear end
just remember that the previous owner could have swapped...
if he had the speedometer re-calibrated, get your speed, transmission ratio (what gear your in), and rear tire diameter and google for a rear end calculator...
if the speedometer is off, you can use a GPS and it should get you close enough...
Old Oct 31, 2011 | 11:23 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Re: Camaro rear end
The Code on the axle will be correct.
Old Nov 1, 2011 | 06:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Camaro rear end
Welcome to TGO, Falconsfan.
The rear is either an open or a limited slip (same thing as posi). In theory the axel tube suggestion is a good one; however, the ones I've looked at were rusted to heck and the numbers unidentifiable. You could also check the RPO's. Since the car is 20+ years old though and may not be original to the car--and who knows when the last time the diff fluid was changed--drop the cover and take a peek. If the rear is a 10-bolt, the link below will help ID what you have:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Nov 1, 2011 | 08:49 AM
92firebird 305's Avatar
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
Re: Camaro rear end
Or you could jack the car up and turn the tires if both tires turn the same way its a posi if not its open you can do it on jackstands to thats what i did .When i went from a 2.73 open to a 3.42 posi out of a 98 4th gen camaro and it made a big difference on my 305 tbi but i have some things done to it im putin down 202 hp and 268 tq to the tires
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
