rear end question
Old Dec 7, 2011 | 09:43 PM
excessiveego's Avatar
Car: 1988 Base Coupe
Axle/Gears: 9 bolt w/ disk brakes - 3.70
rear end question
I have two spare rear ends, one is a 9 bolt with a gov-lock posi and disk brakes, the other is a 10 bolt with unknown posi unit, i believe currently 26-spline axles and aluminum drum brakes.
I am building a 400ish HP 383 with a TKO 5-speed behind it, the question is which rear end am i better off building up to handle the power?
Old Dec 8, 2011 | 07:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear end question
The 9-bolt is somewhat stronger. IIRC, the 9-bolt wasn't equipped with a Gov-Loc, so you might considering verifying as the Gov-Loc has a very poor reputation here on TGO. Disc brakes are a plus and the 9-bolt would have 28-splind axles. Parts are more difficult to come by.
Here are a couple of links that might influence your decision:
https://www.thirdgen.org/forums/faq-...now-about.html
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
