Rebuilt 700r4 cost, upgrades, opinions...
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
well i havnt been here in a few years but im back for now...
my gta needs a new trans, i can get one with this spec list for 1500cad give or take:
Master Overhaul Kit, High Energy 3-4 Frictions, High Energy Extra Wide Band, Brand New "Lazer Straight" 2-4 Brake Drum, Unbrakeable Sun Gear Shell, .500 Boost Valve, .378 Lo/Rev Boost Valve to increase Line Pressure in Manual 1st and 2nd Gear, Corvette Servo Piston, B&M Street & Strip Shift Kit, Teflon Pump Bushing, Filter, a 1-2 super servo, rebuilt heavy duty stock TC.
im mechanically inclined but know next to nothing about transmissions. i know all that stuff is essentially what i want in a trans. if im doing it once do it right.
is there a taller fourth gear i can use to keeps the rpms lower at highway speeds?
thanks for the help! reading everything on this forum again is making me regret not driving my baby.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: Rebuilt 700r4 cost, upgrades, opinions...
The only aftermarket gears that I am aware of change first and second gear. Pretty sure you are stuck with 1:1 for third and .70 for fourth gear.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Your easiest upgrade to get a lower final drive ratio would be to swap your 3.73 rear end out for a 10-bolt 3.42/3.23/3.08 or 2.73. Or got 9-bolt equals of 3.45/3.27(what i have & have hit 21mpg from my TPI/350/700R4)/3.08 or 2.72.
Depends on how much off-the-line "grunt" you are willing to sacrifice to get highway mpg. If you are mainly a city driver.....Go too low & it could be worse mpg because of the engine having to work harder during constant stop & go.
Car: GTA
Or grab you a http://www.gearvendors.com/index.html unit, slap one on & get Double Overdrive out of it, but those aren't real cheap, especially for a car that is barely driven.
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
that .37whatever int/rev valve is a lil big. i'd probably only go .3 max, normally a .296 with the corvette servo is enough to break the tires loose on a manual 1-2 upshift with the plate drilled to b&m specs and their spacers at the 1-2 accumulator installed. honestly i only really like a .3 and larger valve for 200 4-r's. while the separator plate is off you could block 4th accumulator with an extra checkball into the case at the channel hole into the piston/tap it in and stake it in a lil. that will firm up 4th a lil but hardly noticeable. as a bonus it will increase your band life on the fourth gear shift.
Axle/Gears: 3.36
oh man i didn't see you listed the servo twice. a super servo is great, so is a corvette and it's a lot cheaper. the super servo gives 90% versus the 60% corvette. the vette is rated over 600hp and with the wide band it will be snappy enough.
someone972
Aug 30, 2015 12:52 AM
