Rear end Rebuild..Help Advice Needed!!!
Car: 1985 z28
Engine: 5.0 LG4
Transmission: Built 700R4
Axle/Gears: 3.08
Hello everyone I'm no gear head or by any well informed when it comes to a rear end...So I have a 1985 z28 with the stock 10-bolt with 3.08s. I'm wanting to rebuild because the rear end is beginning to whine a little plus it could use it anyways....I'm definitely wanting to beef it up a little bit....Would 3.42s be a good choice on the gears and what else would help....I want the car to still be driven on almost a daily basis....Advice is appreciated!!!
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Rear end Rebuild..Help Advice Needed!!!
don't bother rebuilding it.grab a rear from a v6 camaro.most are 3.42 geared and are the same as the v8 rear.i did.
Car: 91' bird(WS6>>305TBI), 82'Regal
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Rebuilding a 10 bolt can be expensive.I rebuilt mine with the best I could find.
Its a street car with street tires . Had a Professional build it ,and he said if I can break it he would replace it for free.Here's a link to showing some of the work being done = https://www.thirdgen.org/forums/tran...de-photos.html
Car: 1985 z28
Engine: 5.0 LG4
Axle/Gears: 3.08
Yea, mine is a street car too. That was the same setup I was wanting to do 3.42s and a posi. I don't mind spending some money on it as long as its built right and will last. It looks good by the way.
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
