HELP!!!!!!!!!!! t5
Car: 92 Camaro RS
Engine: 350 :)
Transmission: 5 Speed
Axle/Gears: 3.73 posi 10 bolt
HELP!!!!!!!!!!! t5
Hey all, i have a huge ?. i have a t5 with a 350 bolted to it. the clutch went out of it. ive bought 3 clutches and the first had too many splines, the second someone had " sticky fingers" and the last worked great! The last clutch went on the tranny fine but the bell housing is way too small. so the ?
How can i fix this!!!!!
Car: `86 SS / `87 SS
Re: HELP!!!!!!!!!!! t5
Update your profile if you no longer have a 2.8L to avoid confusion.
If the starter that fits your flywheel has 2 bolts the same length installed diagonally from each other, your flywheel is a 168 tooth and too big for an F-body T5 bellhousing.
That bellhousing requires a 153 tooth flywheel which takes a starter which uses unequal length bolts which are in a straight line left-right from each other.
You might clarify where the bellhousing is too small.
Posting pictures would be helpful.
