cant get trans oil pump out, need help
Car: 1985 Z28
Axle/Gears: 3.90 10 bolt eaton posi
Hi,
thies is a 1985 700r4 trans.
I have the oil pump loose, from prying it up through the filter hole, and also removed the selanoid. But the pump only goes up about 1/2inch and stops. Is there something i have not done? Im afraid to put too much pressure by prying it out.
Thanks,
Thanks,
Car: `86 SS / `87 SS
Re: cant get trans oil pump out, need help
proper puller is your best option.
triple-make-sure everything from underneath holding it is removed.
I've held the stator support with a medium (4" capacity) bearing splitter and a slide hammer to tap one out but the stator support was junk.
Car: 1985 Z28
Thanks for the info. I will see if I can come up with some sort of puller.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Car: 1985 Z28
I got it! I had an old valve spring compressor "the kind you can rent from autozone" laying around that I was able to use with a pair of vice grips to make a puller. Basicaly gripped the bottom of the spline with the part that is supposed to grip the bottom of the spring and used the vice grips to hold it in place.
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
eightsixseven
Dec 16, 2024 01:50 PM
maroe624
Apr 16, 2017 08:29 AM
beachrodder
Aug 25, 2015 08:05 AM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
