rear end newb question
Old Jan 11, 2012 | 11:47 PM
Camarobuild18's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: 305 TBI, planning on built 400
Axle/Gears: 2.73 stock axles
i have a 91 camaro RS and i googled the size of the differentals and what size ring and pinion was required cause the 10 bolt is simple i thought... But i dont know what size it is. Theres like 5 different size gm ten bolts and i cant figure this out. Could you help me? Please thank ya. Is it a 27 spline and is it like 8.5? I just need the all sizes and dimensions on this. Even if its 2.73 i am going to swap gears ring and pinion i just need all the gm ten bolt spec fors this to do so
Old Jan 11, 2012 | 11:58 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
Re: rear end newb question
stock would be the 7.5, and 91 iirc should be 28 spline. If you plan on making power I would go with an aftermarket diff.
Old Jan 12, 2012 | 06:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Not that it matters, but your 91 has a 7.6 (vs the 7.5) with 28-spline axles. Check the 10-Bolt FAQ at the top of the page for all the info you require.
JamesC
Old Jan 13, 2012 | 01:19 AM
thanks ill check it out. What kinda differentals would you prefer? Im looking to spend some $$ on drivetrain if it meets application demand.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
