any good?
Old Jan 23, 2012 | 01:09 AM
J0386's Avatar
Car: 1988 formula firebird 350
Engine: 350 tpi
Axle/Gears: Bw 9 bolt 3.27
any good?
Hi I just picked up this rearend to swap into my 88 firebird up for only $60 and was wondering if they are any good, i know its a posi but dont know the ratio any info is appreciated
Old Jan 23, 2012 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: any good?
If the rear is a 10-Bolt, check here:
https://www.thirdgen.org/forums/tran...-10-bolts.html
If a 9-Bolt, check here:
JamesC
Old Jan 23, 2012 | 02:22 PM
J0386's Avatar
Engine: 350 tpi
Re: any good?
Ok its a tpi 305 5.0ho auto 86 trans am 9bolt with 3.27 so it should bolt right up to my 88 tbi 305 would there be any good difference to the swap other then the luxury of 4 wheel disk and limited slip? i dont race or get down on my car at all
Old Jan 23, 2012 | 03:53 PM
JamesC's Avatar
Re: any good?
Yes, it'll bolt up, though you'll need to consider a disc combination valve for best brake performance, parking brake cables, and probably drive and/or driven gears for the trans if you want the speedo to read correctly. All good if you wants discs (though the standard iron Delco-Moraines aren't the best), L/S, and a better gear ratio.
JamesC
Old Jan 24, 2012 | 12:56 AM
J0386's Avatar
Engine: 350 tpi
Re: any good?
Thanks for all the help but im having a hard time figuring out what drive and driven gears to use i tried figuring out through the stickie but have no idea.. and as for the disc combination valve would i be able to add it later on after the swap?
Old Jan 24, 2012 | 07:07 AM
JamesC's Avatar
Re: any good?
Yes.
JamesC
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
