700r4 Slipping MAYBE
Old Jan 30, 2012 | 08:31 AM
Ticeblue's Avatar
Car: 91 RS
Engine: 305 TBI
Transmission: 700R4 shift kit vette servo
Axle/Gears: 3.73 Eaton Posi
I start out in drive can give it light to moderate gas and it will shift good, but once I put my foot into it, the motor will rev to a certain point then it feels like the transmission slips maybe, but it wont shift gears until I let off the gas and then it shifts normal.
Any Ideas....if I need to rebuild it, what would be a good transmission to replace it with that is a direct fit to a 305tbi?
Old Jan 31, 2012 | 07:43 AM
Ticeblue's Avatar
Car: 91 RS
Engine: 305 TBI
Re: 700r4 Slipping MAYBE
Anyone have any input?
Old Jan 31, 2012 | 08:01 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Call Dana at probuilt.. do a quick search. great shop.
Old Jan 31, 2012 | 09:44 AM
Ronnie Brennan's Avatar
Car: 1986 Camaro
Engine: 355 N/A mind 400hp build
if you get your answer pls post it here for others too that read... I'm curious!!
Old Jan 31, 2012 | 11:16 AM
'84thunder's Avatar
Car: 1984 Camaro sport coupe
Engine: 5.0(H/O) 305 carb'd
Transmission: TCI St. Fitr stge 2 700r4 man.valve
Axle/Gears: stock gears, Limited Slip
i had a 700r4 that had same problem. your problem is a hydraulic problem internally. take it to a shop because you will need special tools and parts to fix. better let them do it so you wont break anything.
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
