quick question about manual swap
Old Feb 9, 2012 | 11:52 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Does it matter what I get the non transmission parts from, ie. I would like to pull the clutch pedal assembly and everything else from my 96 car that had a WC t5, but would all that stuff still work if I wound up putting say, a t56 into the car?
Old Feb 10, 2012 | 12:19 AM
88 TA GTA's Avatar
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
Re: quick question about manual swap
I believe the 4th gen pedals are all the same - I pulled the wire connectors from a 2000 Pontiac Sunfire GT (I believe) and they looked same as mine from a 4th gen Camaro/Firebird. I would compare yours to an actual set from a T56 before proceeding, unless anyone else here can confirm.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
