9 Bolt Rear End Question
Car: 1989 Iroc Z L98
So I am looking at purchasing a 1989 Iroc Z with a 5.7 in it. I have done a few searches on here about upgrading the gears in the rear end, it currently has 2.77s.
What is the most cost effect way of upgrading the gears in the rear end to 3.42's? My understanding is I need a 3 series carrier and gears which sounds expensive.
Thanks in advance!
Thanks in advance!
Re: 9 Bolt Rear End Question
Thanks in advance!
Thanks in advance!
Car: 87 iroc-z
Engine: 454
Transmission: th350
they make 3 series gear sets to fit 2 series carierrs. however, i dont think they make them for 9 bolts? probably gonna be easier to swap rears.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
More like 2" per side for 93-97 & 1.8" per side for 98+. The stock 16" wheels still fit under the fenders but the 93-97 brakes are the same calipers & rotors as the late model 3rd gens so they aren't an improvement in braking. The 98+ will give you better calipers & bigger rotors, but both will be 10-bolts.
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
You can find a carrier and 370 gears; I did. I even found an extra. The 9 bolt is the better rear. It cost more and that is why they dropped it. The 350 cars and TPI cars got the 9 bolt and the lower end cars got the 10.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
