Will this type of trans work for a swap?
Old Mar 18, 2012 | 01:39 PM
karl's-92'-z28's Avatar
Car: Too many cars
C4 ZF 6 Speed Transmission 1989-1996 with Flywheel and clutches Interchangeable Part Number 1052000089 Total Ratio 2.64-0.49 , its from a 89-96 corvette.
Old Mar 18, 2012 | 02:30 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Will this type of trans work for a swap?
Yes and no. It will fit with considerable mods. If i remember right the ZF is a monster and does not fit the tunnel on these cars well requiring spacing it down or modding the tunnel. Also its not really the strongest trans out there. For the money that they are going for and the amount of work required to put them in these cars id stay away from them and look for a T56 or a TKO. TKO requires drop spacers on the crossmember as well but is more of a bolt in kit and can handle 500-600 hp depending on which model you get. T56 bolts right in. Both the t56 and tko are easier and handle more power than the zf and you would probably be ahead of the game price-wise too.
Old Mar 18, 2012 | 02:34 PM
Car: Too many cars
Ok thanks, well they are asking $550, it has only 24,000 miles on it, come with new cluctches & flywheel. Thanks for the info. Are the LT1 & LS1 6 speed th same?
Old Mar 18, 2012 | 02:36 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
A T56 bolts in much easier. A LT1 obviously is a direct bolt in at the bellhousing. Driveshaft can be kept as well. Would need an aftermarket crossmember but thats about it. LS1 T56 needs a bellhousing adapter which I believe runs 200-300 dollars But you can use that with a ls1 clutch release bearing and a gen 1 sbc clutch.
Old Mar 18, 2012 | 02:40 PM
Car: Too many cars
How can you tell the difference between the types?
Old Mar 18, 2012 | 02:42 PM
Car: Too many cars
Their was a LT1 6 speed for $1200 here on CL, came with everything to install on a third, but didnt know the condition of the trans.
Old Mar 18, 2012 | 02:43 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
The bellhousing bolt patterns are different is the most obvious way to tell.
Old Mar 18, 2012 | 02:47 PM
Car: Too many cars
Ahhh got it, sounds like a PITA if you cant tell the difference. But a LT1 would be an easier way to go?
Old Mar 18, 2012 | 02:51 PM
subroc's Avatar
Engine: 355 TPI
LT1 t56 is the way to go. You 'can' make a LS1 t56 work but the cost to convert it over to work makes it the not practical choice unless you get it for free or next to free lol.
Old Mar 18, 2012 | 02:53 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
However I believe the hydraulic setup in a LS1 T56 is much better and worth the offset cost.
Old Mar 18, 2012 | 03:13 PM
Car: Too many cars
Ill just use my Iroc T5 instead...lol
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
colton_carlson
Mar 8, 2019 12:21 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
