Rebuilding rear end
Old Mar 21, 2012 | 01:33 PM
Phillyboy9088's Avatar
Car: 1987 Iroc Z
Rebuilding rear end
So I've saved enough cash now to buy the parts to rebuild the rear on my 87 IROC....buying a master bearing kit, eaton 3 series posi, richmond 3.73 gears, moser 28 spline axles, and a new diff cover. Looking to eventually put 300-350 hp (flywheel) motor in. I know the 7.5 rear is weak, but I shouldn't have a problem in this horsepower range, would I?
Old Mar 21, 2012 | 07:12 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Rebuilding rear end
Richmond gears are cut a lil different and have more noise than motive gears do. So I'm told. I have installed a bunch of both and its true for the most part..
Old Mar 21, 2012 | 07:47 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
This is the cover Im using .
http://www.jegs.com/i/L.P.W./619/301-7.5G/10002/-1
I don't see how you can go wrong with this one.
Congratulation,your going to love the new setup.
Old Mar 22, 2012 | 03:56 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I think youll be fine. Its clutch dumps and sudden traction situations that kill diff's. With all the things you listed and the cover you should be golden.
Old Mar 22, 2012 | 05:16 PM
Car: 1987 Iroc Z
Hey thanks guys. Another quick question..the rebuild kit. Would this be the correct one I can use?
http://www.drivetrainspecialists.com...duct-1783.html
And do I need to buy spider gears or are they in the install kit? Sorry for the noob questions. First time messing with a rear end.
Old Mar 23, 2012 | 08:33 AM
Car: 1987 Iroc Z
Well I ordered the Motive gears instead of the Richmond since I've read from a alot of the posts here that they're quieter. Oh and disregard the spider gear question. Looked it up and saw they're inside the posi. Thanks again guys.
Old Mar 23, 2012 | 03:55 PM
Engine: TBI,5.0
Here's a list of what your going to need. I see you have most of that,you still need the axle bearings and seals and a professional to install it all .If you don't have one already.
1)Master bearing kit
2)Axle bearings and seal
3)28 spline, 3 series ,Eaton Posi.
4)28 spline axles
5)L.P.W. Cover “no gasket,only silicone”
6)ring and pinion
7)installation by a “professional”
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
