Is a lighter flywheel worth it?
Old Mar 30, 2012 | 02:22 AM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
I understand the benefits a lighter flywheel has, but will it be a good idea on my car specifically? It's a mostly stock L98 with a (soon to be) T56 and a 3.70 rear. It's a street car primarily and sees occasional drag strip and autocross use. I'm trying to make it a good all-arounder. The flywheel I'm looking at weighs 18 lbs and the stock LT1 T56 flywheel weighs 28lbs I believe. Will an 18 lb flywheel destroy streetability? Is this a good match for what I'm doing with the car, or am I better off just saving my money and using the stock one?
Old Mar 30, 2012 | 07:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Is a lighter flywheel worth it?
Just a general comment. While streetability isn't really an issue, the light-weight version, because it slows faster than the heavier version, will change the way you shift.
JamesC
Old Mar 30, 2012 | 08:07 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Yes I will change the way you drive it. You'll have to rev it a bit more when taking off from a stop..
Old Mar 31, 2012 | 10:41 PM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Yeah, what they said. It's weird having to rev-match on the upshift when you're not really leaning on it. Under power, everything matches up nice though. And yeah, pulling out take a bit of getting used to. For autocross, it'll be a huge gain due to better transitional response.
I have an aluminum unit of unknown origin (came with the car) which appears to come in at about 11 lb. I would not give it up for anything.
The quick revs are amazing, the off-throttle response is awesome, and I do enjoy the fact that it give the motor a real "racy" sound and feel (normally not into that aspect, but it is freakin cool in this case).
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
