92firebird, lost reverse, and other gears maybe
Car: 1992 Firebird
Engine: V6 3.1L
so just like any other day, i was driving to work parked the car, when to leave work for the day, and went to put the car in reverse,
car didn't move, was like neutral or something,
from what gears it seems like i do have, park, drive, overdrive, 1 and 2
in 1st or what ever gear its in i have to get it over 5,000rpm let off gas before it will shift to the next gear.
from what i notice trany fluid was low, replaced it, and installed a new filter.
it didn't fix the issue.
my next thought is to replace the transmission modulator.
any thought and or help would be very appreciated.
Car: 92 RS t-top
Engine: 350 TBI
Re: 92firebird, lost reverse, and other gears maybe
My 700r4 did the same exact thing last week and I still haven't gotten any help from my thread I'm just gonna beef up my tranny and throw a new torque converter in it... Good luck man
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
It could be your hydraulic pump, mine did similar things before it blew up.
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
It's a common problem with 700r-4 &4l60-e trannys its the sun shell
Car: 1992 Firebird
Engine: V6 3.1L
would a Chevy th350 have the same bolt pattern as the current installed 3.1v6 trany?
what you i require to install this trany for it to work correctly?
sensors bypass?
vacuum bypass?
sensors bypass?
vacuum bypass?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Shame you are so far away, i just pulled the auto out of my 92 v6 car, perfect shape, 80k miles, im just changing to a 5 speed.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I have the same problem and someone else told me that the sun shell is busted and not to drive it very much before fixing it. How hard a fix is this project going to be? Anyone with any ideas?
Hotrodboba400
Dec 10, 2019 07:07 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
