1992 Camaro RS
Old Apr 20, 2012 | 10:02 AM
Frank Telli's Avatar
1992 Camaro RS
I have a '92 RS 5.0 TBI and i need gears for my rear end, my question is can i use rearend gears with ratio 3.42 out of a late 90s model RS
Old Apr 20, 2012 | 10:24 AM
krisner89's Avatar
Car: 87 camaro
Transmission: th350
Axle/Gears: auburn 4.10
Re: 1992 Camaro RS
depends on what gears you have in there now. I would guess a 2.73 and if it is it will not work because 3.08 and down ratios have a series 2 carrier(differential). 3.42 calls for a series 3 carrier
cheapest way to get a 3.42 ratio is to find a v6 camaro in the junkyard, pull the cover to be 100% sure that its a 3.42, and remove the whole rear end, brake drum to brake drum. it'll cost u around 100 bucks and its ready to bolt in. you'll have over 100 bucks in the installation kit alone(shims,crush sleeve, bearings,seals, etc...) to change gears in a rear end. then you have the gear cost, pay someone to do it or buy the tools and do it yourself. gets expensive when there is a ton of them ready to go in junkyards that already have that ratio.
Old Apr 20, 2012 | 12:58 PM
Re: 1992 Camaro RS
Thanks man you just saved me alot of money Thanks again
92camaroJoe
Jul 29, 2023 07:57 PM
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
