700R4 TORQUE CONVERTER DRAINBACK ??
Old Apr 29, 2012 | 05:37 PM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
700R4 FEELS LIKE SOMEONE PUSHED IN THE CLUTCH ON A MANUAL GEARBOX WHEN TRYING TO ACCELERATE. ENGINE RPMS SPIKE BUT NO DRIVE. SEEMS LIKE TRANSMISSION IS NOT EVEN THERE. PULLED DIPSTICK AND FLUID LEVEL IS VERY HIGH. LOOKS LIKE TRANSMISSION HAS BEEN OVERFILLED. TRANSMISSION ACTING LIKE T/C IS FULL OF AIR. DOES THIS INDICATE TORQUE CONVERTER DRAINBACK ??
Old Apr 29, 2012 | 06:01 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 700R4 TORQUE CONVERTER DRAINBACK ??
The ATF is supposed to drain back, as you call it, but not quickly / dramatically / completely, as you make yours seem. Maybe it has a loose, cheap high-stall converter, have you ever driven one before? If not, be aware that they feel looser with a 2.73:1 rear than with a 3.73:1 gear, but even so, they should make tire-spin easy once you bring the revs up enough.
Old Apr 29, 2012 | 06:36 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
This indicates your transmission isn't going into gear.
Old Apr 30, 2012 | 05:50 AM
DRIVE2FAST's Avatar
IT DRIVES NORMAL AT LOW POWER SETTINGS BUT OPEN THE THROTTLE JUST HALF WAY AND IT COMPLETLY DISENGAGES. RPMS SPIKE. WORSE THAN SLIPPING . FEELS LIKE THE TRANSMISSION ISNT THERE. OUT TO LUNCH , NOBODY HOME. FLUID LEVEL IS EXTRMELY HIGH ON THE DIPSTICK ,,, ALL THE WAY TO S-BEND IN THE DIPSTICK WHEN WARMED UP. FLUID IS CLEAN AND SMELLS OK.
Old Apr 30, 2012 | 02:05 PM
Car: 1985 Z28
What was the last thing you were doing when it still drove normally?
Hotrodboba400
Dec 10, 2019 07:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
