When should an aluminum rear end girdle cover be used?
Old May 19, 2012 | 05:30 PM
syoung_2000's Avatar
Car: 1991 Firebird Formula
Transmission: 700R4 to WC T5 swap
Axle/Gears: 2.73 drum to 3.73 PBR swap
I have the rear end out and I'm about to paint things. I'm trying to decide whether to keep the stock rear end cover or not.
I have a 1991 305tpi & T5 with plans for modifications that likely won't break 260hp.
I have 3.73 Richmond thick gears and the rear end was just rebuilt.
Is it typically guys putting out big numbers that need these for strength?
I won't be drag racing it. It will be DD status with occasional aggresive driving.
So...should this rear have an aluminum girdle cover or should stock be good enough?
Thanks!
Old May 19, 2012 | 06:02 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: When should an aluminum rear end girdle cover be used?
OE under those circumstances should be good.
JamesC
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
