1984 LG4 Trans AM -10 Bolt disk to 9 bolt drum swap
Old May 29, 2012 | 08:29 AM
wallyj's Avatar
Car: 84 TransAm
Engine: Vortec 383SBC
Transmission: T56, Stage 2 Ram clutch
Axle/Gears: 7.5 w/28 spline axles and 4.10 LSD
Hey all, I am looking for some info and cant find what I need on my search. I have just obtained a drum brake 9 bolt posi with 3.42's, and want to swap it in my stock disk brake rear Trans-Am (open diff 3.23).
My question is: Will the stock disk brakes from my 10 bolt swap on directly to the 9 bolt housing? The 9 bolt's drum backing plates are shot, I am crossing my fingers I can bolt on the disk assy from my ten bolt and make everything nice and easy.
I know my ten bolt rear disks are not ideal, but I'm trying to keep costs down right this moment, I just finished my 383 install with mild stall, and anticipate some serious traction issues..
If it's a no go and the only option is 9 bolt specific brakes, I'll wait for a 4th gen rear, or upgrade the 10 bolt to posi when time and money allows.
Any help appreceated!
Old May 29, 2012 | 10:53 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 1984 LG4 Trans AM -10 Bolt disk to 9 bolt drum swap
At least the mounting plate is different. They can be had for $60-$80 or so.
Old May 29, 2012 | 12:15 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The drum and disc axle flanges are different, so modification would be required Moreover the 9- and 10-bolt have different bolt patterns. You can purchase the correct backing plates for PBR's, but not for standard discs.
JamesC
Jorlain
Aug 24, 2022 05:11 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
colton_carlson
Mar 8, 2019 12:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
