Can spider gears be changed in stock 10 bolt posi?
Old May 29, 2012 | 09:23 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
I had new bearings, gears, axles, aluminum cover with a girdle and backbrace put on my 10 bolt, first time I got second gear hard the spider gears broke in the old stock posi unit. Looks like the auburn unit to me, but no parts are available for it and as I understand it, it's not serviceable. I don't see why the spiders cannot be changed though, I do have access to another stock posi unit for parts so I can try to stay away from setting up the gears again. Is it possible to change them? Just don want to waste my time or money buying the posi to swap guts if it's not do-able and I need a whole other unit anyway. tIA
Old May 29, 2012 | 03:30 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Can spider gears be changed in stock 10 bolt posi?
You can steal spiders from an identical Auburn, but you're likely to break those. I love the Auburn for a daily driver, but only if the owner is willing to do frequent lube changes. Otherwise Auburn's friction stuff contaminates the lube, and accelerates wear of the gears, c-clips, and bearings. Not good.
Old Jul 12, 2012 | 04:03 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
is the eaton unit superior then? as i plan to do this upgrade soon
Old Jul 12, 2012 | 04:26 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
In theory, the Eaton is more serviceable parts-wise.
Like Tortilla said, the Auburn contaminates the fluid with wear and he hasn't implemented the Dana 60 particulate filter/pump system for the third gens yet.
But... Auburn parts are listed... which kinda doesn't matter if the case itself is ground out.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
