finally a 100$ t5!
Old Jun 5, 2012 | 08:00 PM
nowerelsetoroam's Avatar
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
finally a 100$ t5!
So I was browsing through craigslist and
Came upon a t5 for 100$.
I thought eh what da hell Il buy it.
After I got it I looked at the id tag and turns out its
A world class t5 out of a turbo thunderbird.
Now since its A world.class I was.thinking of mating
It to my 355 build.
What all do I need To make this work?
I've got the bell housing.
I don't have a flywheel nor clutch. So what brand clutch
And flywheel should I use.
I know the input shaft has to be changed. But is that it?
I plan on rebuilding the tranny wether it works or not.
Any input would be greatly appreciated!!
Old Jun 6, 2012 | 12:19 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: finally a 100$ t5!
slip yoke on the driveshaft needs changed. Not sure if the trans. total length changes too. Measure though.
input as you said; there are multiple lengths; the gear tooth count must match the old one. Since the 60deg V6 bell that mates to the Ford T5 is a 4th gen item, you'll probably need to go with an input from a 4th gen T5.
tailhousing and shift rail if you want f-body shifter location. Ford trans. mount is straight up; GM is angled too.
ford to GM speedo cable adapter
So, savings might be a wash.
sailtexas186548
Feb 17, 2017 03:07 PM
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
kitt23
Nov 4, 2015 05:40 AM
Antips16
Oct 30, 2015 06:42 PM
1nastygta
Sep 24, 2015 08:58 AM
