HELP DETERMINING STALL CONV. SPEED
Old Jul 5, 2012 | 03:54 PM
StevenC20063's Avatar
Is there a way to determine my stall converters speed ? The trans. was already in the car when I bought it. I need to know so I can order a larger cam...
Old Jul 5, 2012 | 08:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: HELP DETERMINING STALL CONV. SPEED
True converter stall can only be found by using a transbrake. The best you could do is to do a brake stand and load up the converter as much as you can until the brakes can't hold you back or the tires start to spin. A flash stall test is your next option.
The converter stall speed is only a rated speed. How much it stalls depends on how much torque is put into it. The same converter behind 2 different engines will stall at different speeds.
The converter needs to be matched to the camshaft for best performance. For street/strip use, the converter stall speed should be around 500 rpm into the powerband. For full race it should be around 1000 rpm into the powerband.
When you look at a camshaft and the specs say 1800-6000 range, that means you need a converter with around 2300 rated stall speed for best performance.
Old Jul 6, 2012 | 09:11 AM
Thanks man ! That was an extremely informative answer ! When I do the brake stand you simply mean locking my brakes (not e-brake) and giving it some love right , as if you wanted to burn out. Correct ?
Hotrodboba400
Dec 10, 2019 07:07 PM
rjcme
Sep 5, 2015 01:23 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
