which clutch kit for t56? need help thx
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
i got a 89 iroc with a t56 from a 97 ss took my engine out replaced gaskets and seals minus head gaskets, put everything back with the same clutch got it started and now i feel like a grinding/ tapping noise im thinking is my throwoutbearing or pilot bearing/bushing? any info on what the problem could be?
so im looking for a clutch kit since im ready to pull my trans out is this competition clutch kit worth it? or should i buy a zoom stock from summit or go with ram, centerforce or mcloed? i know competition is much cheaper and ive read so many good reviews on it i just need a site that will sell the stage 2.5 for under 300 anyody knows anything let me know thanks
http://www.ebay.com/itm/COMPETITION-...-/230632461913
Re: which clutch kit for t56? need help thx
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
this is a very good one... im getting this one for my swap pretty soon....
mcleoad clutch disk - http://www.summitracing.com/parts/MCL-261171/
lt4 clutch pressure plate - http://www.autozone.com/autozone/cat...ndName=Duralas
your buying a seperate clutch disc??
or going with the kit from autozone?
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I did the same thing and it's been working great. You use the pressure plate from the Autozone clutch kit with the McLoed disc.
Hmm you spending 400+ doesnt sound bad might just do that
If im pushing around 280-300 is a stock one good or the zoom from summit? Or is a stage 2 better ?
Night rider327
Sep 2, 2015 04:17 AM
1988, 57l, 89, camaro, clutch, competition, high, iroc, kit, performance, stage, t56, trans, transmission, zoom
