Gear ratio
Old Jul 11, 2012 | 06:48 PM
Shane4524's Avatar
Car: 1986 Camaro IROC Z28
Engine: 5.0L 305 TPI
Gear ratio
The rear end differential has gone out in my car and I am in the process of ordering a new one. My choices are the 2.73 or 3.23 which came stock in my car but I am not sure which one to get because I am not sure what's in my car. Is there an easy way to tell or should I just go with the 3.23 or what?
Old Jul 11, 2012 | 08:21 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Gear ratio
go 3.23 if those are your only choices.
Old Jul 11, 2012 | 08:27 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Re: Gear ratio
Old Jul 12, 2012 | 03:28 AM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Re: Gear ratio
The 2.73's will be a little better on the freeway, but the 3.23's will be more fun and have a better launch. Go 3.23's and get a posi/limmited slip if you can
Old Jul 12, 2012 | 06:37 AM
Shane4524's Avatar
Re: Gear ratio
Oh yes, I am definitely getting a posi. And the car doesn't see freeway more then maybe a couple times a year to go home from college.
Old Jul 12, 2012 | 06:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Gear ratio
2.73 is a series 2, 3.23 a series 3. For more info, check the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
