Rear End CArrier Side Bearing Puller?
Old Aug 4, 2012 | 10:02 AM
Dark Ember's Avatar
Car: 90' Firebird Formula 350
Hey guys, I have been trying to remove the side bearings from a carrier unit I have, and have had no luck. What tools do you guys use to remove these?
I was wondering if anyone has ever used something like this successfully? TIA, Rodney.
http://www.amazon.com/OTC-4520-Diffe.../dp/B0015PMZN4
Old Aug 4, 2012 | 10:14 AM
Re: Rear End CArrier Side Bearing Puller?
A "jaw" puller will work on some carriers.
About the only way to know if it'll work on yours, is to try it.
The odds are better with a 3 series carrier because the ring gear end of those is more cone-shaped, less flat, than a 2 series.
The standard shade-tree method is to slot the bearing with a small wizz wheel or something, then split it with a chisel. USE EYE PROTECTION and do it out in the open away from anything that can break from high-speed flying debris if you decide to try this!!!
Old Aug 4, 2012 | 10:55 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I'd go for a bearing splitter. Best used with a press, but a 2-jaw puller is another method.
Old Aug 4, 2012 | 09:35 PM
whitelightnin92's Avatar
I cut and split them. A puller will do it but they usually slip and ruin the bearing cage anyway
Old Aug 4, 2012 | 10:22 PM
project89's Avatar
i usuually cut the cage off with a torch so everything but the inner race falls off , then ill cut the bearing race with the torch on one side and it will fall off.
i dont recomend any novice to try this as u are more then likley going to torch the surface the bearing gets pressed onto and possibly ruin the carrier
simplest method for most ppl will be to ise a tiny cutoff wheel and cut the outer bearing cage to get to the inner race and slice it with the cutoff wheel. u dont have to cut all the way threw the race, u leave just a lil bit of material left and use the chisel to make it split
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
novaderrik
Aug 10, 2015 12:44 PM
