700r4 question/issue
Old Aug 22, 2012 | 06:19 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
Short background...
2009:
85,000 trans goes out.
Rebuilt original in lieu of a replacement.
Car has 88,000 now. So 3000 miles on trans.
Ok to my question...
I do not know if it has always done this or not. I have noticed the shift indicators are a little "off" but I know what gear I'm in by feel.
I'm in the midst of a reprint and the car is on stands, wheels off. While working, car in park, I notice the rear wheels can still be turned by hand! Why? I'm hoping it's as simple as the linkage needing adjusted as its just not locking in Park.
Once the job is done is going to the local speed shop who has a third gen nut to burn a chip and check it over. Just curious if you all have any ideas.
Thanks!
Old Aug 22, 2012 | 06:50 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: 700r4 question/issue
Disconnect your shifting cable at the transmission. The move the shifting lever on transmission into park. Now put shifter all the way into park. Adjust the cable at the transmission to line up with the shifting lever on the transmission.
Old Aug 22, 2012 | 07:09 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Adjust your shift cable. It's likely not allowing the lever on the trans to go all the way into park. You can disconnect it at the trans and throw the lever all the way forward to verify that it will lock in park.
Old Aug 22, 2012 | 07:53 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
When under the car, shifter in park, you can move the lever on the trans forward. I figure that's the problem. I'll adjust it.
I was just wondering if I was missing something but I figured that's it.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
