Heavy Vibrations - T56
Old Sep 7, 2012 | 05:07 PM
PeterFeix's Avatar
Car: Trans AM GTA 1989
Engine: 383 HSR AFR195 JRC Cam280/286
Transmission: T56 Conversion
Axle/Gears: 3.27 9bolt
Hi all!
Hope you know a way to fix this.
I have a 89 GTA with a 383 and T56 Swap.
I'm using the Energy Suspension Polyurethane Bushing ( the Stock Bushing was really too soft, so the Shift stick travelled too much downwards while hard accellerating ). I doubt this part would last longer than a few weeks before being ripped into pieces by my engines torque *g*
Don't know if it is the ES Bushing , but when I go full throttle, I have alot of vibrations and noise when I press the clutch pedal. (From 2-3 Shift until 5-6, 1-2 is still ok/quiet)
Is there any way to avoid this? Maybe some greasable bushings? Or is this common behaviour?
Thanks in advance
Alex
Old Sep 7, 2012 | 05:22 PM
BOTTLEDZ28's Avatar
Transmission: A4
Re: Heavy Vibrations - T56
Did the problem begin after you installed the poly mount or was it doing it prior
Old Sep 7, 2012 | 10:39 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Get the shorter energy suspension mount. The one that's sold EVERYWHERE is too tall and it puts the driveline at incorrect angles.
Or.. if you weld the torque arm bracket to the crossmember and get it off the transmission, you can then get good life out of rubber transmission mounts, which will also allow for quieter operation.
Old Sep 8, 2012 | 06:12 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by PeterFeix
I'm using the Energy Suspension Polyurethane Bushing....
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
Old Sep 12, 2012 | 04:03 AM
PeterFeix's Avatar
Thanks alot - Didn't know that the ES Bushing can couse those problems.
I'll try to remove the preload plate, if it works - ok. If not - I'll get the prothane.
thanks again
Alex
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
